Heater control rebuild with a.c.
Started by 1968shelbygt350h, May 08, 2018, 08:24:52 AM
1968shelbygt350h
Looking to rebuild and replace my heater control valve
Please let us know if you can find someone to rebuild iy
Quote from: Coralsnake on May 08, 2018, 08:35:49 AM
+1 . No one I have heard of rebuilds a faulty vacuum diaphragm or can replace a rusted away disc that stops the water flow. The best you can hope for is a NOS or a still working valve and cosmetically restore it for show . If the new look is not that important then a used unit. Be sure that it holds vacuum and that the valve inside is still intact and moves freely.
1968shelbygt350h
I have 2 both diaphrams are good I opened 1 and the valve seems fine and the small black seal and it goes up and down with vacuum but it leaks at the bracket with the 3 small screws dont know if it had a gasket and fell apart
Quote from: Coralsnake on May 08, 2018, 11:11:00 PM
There was a small oring there
+1.  The O ring does the trick . That is if you can get at it to replace the o ring. Some times one or all of the three slotted screws seize up and are hard to take out if at all.
