What flashers are used for 69-70 Shelbys
Started by Dan353, May 09, 2018, 12:35:10 PM
Dan353
I'm trying to find out what flashers are used for 69-70 Shelbys?  Is the emergency flasher the same as the one for the turn signals?  What are the part numbers that will work and where can I purchase them?  I'm trying to fix my rear lights and I'm not sure if I have the correct flashers I have change the black box but still have the same problems.
Thanks,   Dan
The flashers are not the same. I know in 1969 they had actual Ford part numbers on the cans. The important one is obviously the turn signal flasher. There are specific flashers for the six bulb system, do not use a substitute or interchange part.
Dan353
Does anyone have the correct part numbers for the signal flasher and the emergency flasher?
    Dan
