67 GT350 Choke Cable to Firewall Clip
Started by rcgt350, January 10, 2022, 10:30:50 PM
rcgt350
Im on the hunt for the hold down clip that secures the choke cable tooth firewall on a 67 GT350
NPD has two versions, which one of these would be the one to use and which fastener screw?
greekz
Quote from: rcgt350 on January 10, 2022, 10:30:50 PM
When I bought my GT-350, #2339, in 1987, it had the clip with rubber coating and a hex head screw attaching it to the firewall.  However, I was told some years ago no clip was used to secure the cable at the firewall.
SFM 6S1134  '67 GT-350 #2339
rcgt350
Ok, well I have a hole in the firewall where there was a sheet metal style screw, but that's it.
Did you leave the J Clip in place or remove it?
greekz
Quote from: rcgt350 on January 11, 2022, 09:54:11 PM
I left the J clip in place.  It serves a useful function.
68gtcoupe
Would anyone be willing to share a photo showing how the choke knob is positioned inside the car and how the cable comes out of the firewall and is routed to the carburetor?  I will be adding a manual choke carburetor to my 1968 Mustang GT this spring and would welcome tips for ensuring a smooth operating manual choke. Thanks so much in advance.
greekz
Quote from: 68gtcoupe on January 12, 2022, 10:24:24 AM
Here are some pictures of my choke setup.  This is how everything was in 1987, when I purchased the car after sitting for 9 years. Others may have a different routing.  Hope this helps.
Sorry, I do not have a picture of the choke knob, but is on the far left by the kick panel.
68gtcoupe
Quote from: greekz on January 12, 2022, 11:17:27 AM
Yes great, thank you very much!  Huge help. Much appreciated!
Your engine appears to be a 4 speed and because of the attention to assemblyine detail on the engine I thought I would mention that the dashpot was only typically added to automatic cars that came equipped with Holley's.
greekz
Quote from: Bob Gaines on January 12, 2022, 11:28:59 AM
My car is an automatic.
  My 67 GT 350 #0036 has the upper clip shown in the photo.  No coating on it. Hex bolt
the car I had was missing the choke cable "clip" but the hole was in the firewall I added the top one in the photo.
Here are some choke cable pull-knobs on '67's (not sure if '68's are the same)
On this topic - the very early GT350 cars had the choke cable AND the amp gauge wires AND the oil pressure line ALL jammed through the "Ford" choke hole in the firewall!
Yes, so thankfully someone figured although it can be done not such a good idea so, about mid -Dec Shelby workers were adding an additional hole to route the amp gauge wires AND the oil pressure line through.  (Relevant to the original poster.)
Here are some images of the two versions.  First image is a double-digit car, the second and third images are the same car during restoration and is a low 1xx number car - both cars completed at Shelby before the end of December '66.  The forth image a later car note the added hole was not always added in the same place - worker prerogative?
On the GT500's this additional hole was not needed since they had electric bi-metallic "automatic" choke an the Ford Choke hole was "open".
Quote from: JD on January 12, 2022, 10:41:32 PM
Can't think of an application for a passenger car with a manual choke in 68
S7MS427
Quote from: JD on January 12, 2022, 10:56:16 PM
On the GT500's this additional hole was not needed since they had electric choke an the Ford Choke hole was "open".
Don't think the G.T.500s used an electric choke, just a standard automatic one.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Quote from: S7MS427 on January 13, 2022, 10:21:20 AM
Roy, good point - poor/wrong use of word on my part, I'll adjust ;-)
