Interior door paint
Started by GT350Lad, January 22, 2022, 06:17:45 PM
GT350Lad
Hi guys, about to start thinking of interior paint planning on my 2 66s. I have done plenty of searching and it appears interior door colour is same as rest of interior and dash? It always looked a bit glossier to me but maybe it's my eyes.
Paint I am planning is SEM trim black or another close for it all and engine bay. Spray Gun applied
Just confirming
6S373
6S1276
NC TRACKRAT
SEM is good stuff.  I think it's "Tuxedo Black".  Be sure to give it a couple of days to "cure"....The longer the better.
5S071, 6S1467
GT350Lad
Nice. So use "tuxedo black" over trim black?
I was planning trim black
Can SEM trim black be used?
Cheers
6S373
6S1276
GT350Lad
6S373
6S1276
Remember, if your considered with original details, the interior paint was applied first then the exterior paint. Also the paint line does not follow the weather strip around the outline as you may see on some cars. There is also a "notch" at the top rear edge of the paint that extends rearward from the rest of the paint line along the back masked edge of the interior paint
GT350Lad
Thanks Jeff. Always keen on details
6S373
6S1276
kram350
Jeff, Can you post a few pictures if you get time showing the door paint details as stated in your post? Thanks for what you do.
Of course I can. Know there is a thread over on CMF may just cut and paste but will post something here showing the details
GT350Lad
And is everyone happy the SEM trim black is an ok match for interior panels, dash and door inside metal?
Cheers
6S373
6S1276
davez
This may be a bit involved for some , for the restoration of 6s1127 I use ppg shopline black with a matting agent. I have test panels sprayed with mixing ratios of black to flattener of 5-1, 4-1, 3-1 , 2.5-1, and 2-1. I compared 3 original paint ashtrays and  2.5 -1  seems to be the closest level of sheen. With the test panels sprayed I use those for the various black parts on the rest of the car.
davez
GT350Lad
Impressive. It's always hard to match it 100% bi that's pretty Damm close
Nice one
6S373
6S1276
As promised
As mentioned above the interior paint was applied first. For 65-66 this means the doors, dash and A pillars. These areas were then masked off either free hand or some form of precut mask that was tapped in place. Because of this you can get areas where the paint (exterior color) could blow under if not tapped or the mask lift for a section and produced a softer paint edge
At the top - Window and vent window edge
At the rear most of the edge is located where the weather strip would be attached except at the very  top at the rear where the paint extended further as shown
And at the bottom of the rear edge the mask/tape pulled in and away from the weather strip impression in the door edge.
This could be done neatly or a bit messy with ends and pieces of tape in the say as shown
As we look at the bottom of the door we find that the mask did not follow the weather strip impression and track area. Instead we often find a straight edge produced from the taping of the mask or in some cases a less than perfectly straight line.  Also painters, either interior or exterior ones, didn't always put the effort in on a particular car to bend over far enough to apply allot or in some case almost any paint to the bottom edge making the paint lines difficult to see. On other examples a good coat of paint was applied as seen in the pictures below
Not much paint for interior or exterior on the bottom of the door on the left while on the right a nice coat of both on this example
More difficult to get pictures of the front edge of the door but here is an example. After the transition at the forward bottom corner like at the rear the paint line travels to the weather strip impression then takes a straight line to the upper weather strip impression and into the window opening from there
Though it may not matter since its an unseen detail, for what ever reason San Jose workers choose not to mack off the center of the door surfaces where the door panel would eventually be attached
Hope this helps others
