289 Block
Started by plowhorse, May 14, 2018, 11:48:18 PM
plowhorse
WTB...289 Block with 5M or early 6A date code.
OldMil
I have two blocks-
5K26
5L27
Not sure if either will work for you.  I'm located in Tomahawk, Wi.  Thanks, Jack
Bigfoot
Aren't the blocks identical?
RIP KIWI
RIP KIWI
427heaven
Blocks are,main caps are bigger on Hipo- ;)
69mach351w
OldMil
I believe the block is machine matched to the caps, but this can be done to any block.  Same blocks.
