Dash pot purpose and function
Started by Corey Bowcutt, February 21, 2022, 01:26:46 PM
TA Coupe
Try spraying a small amount of silicon lubricant on the plunger and see if it frees it up and it starts working again correctly.
        Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: Bob Gaines on February 22, 2022, 06:22:32 PM
The 68 Holley dashpot bracket is different then the 69 version.
Do you have a side by side comparison Bob of the brackets? My pic was to show Corey the Dash pot and placement for a Holley. That Holley on my 70 is a U service replacement and bolted on at a show to replace a problematic 67 390 Holley  carb and I haven't taken it back off yet years later because it runs too good. My 4300 is shelved and has been for a while.
Bob, my friend is contemplating putting a Holley on his engine(currently had AL intake and 4100) and wants to make sure it has the correct dashpot bracket. Gary
Corey Bowcutt
I sure wish I could post a picture of my setup.  It agrees with others that have sent me pictures for a 68 GT350 Holley setup.  But it is very different from the pictures shown of the dashpots mounted to the Holley carb specifically reply #20.
BTW I have lubricated my dashpot with no luck.  It slides in and out full travel pretty smoothly but clearly takes more force than my return spring provides.
Corey
Corey Bowcutt
With a little experimentation I was able to post a picture.  Not easy but at least it worked.
Corey
68gtcoupe
Quote from: Corey Bowcutt on February 23, 2022, 08:12:51 AM
Corey
Being that is an original spring Corey, perhaps finding a new (stiffer) one and finishing it so that it at least "looks the part" might be an option.
Terry
Looks like your application uses a C8 Autolite dash pot with the 600 CFM Holley carb.
The one in post #20 is the Holley dash pot you can buy right now from Holley. Not correct for your application.
The return spring and bracket should look like this if they are properly installed.
Quote from: Royce Peterson on February 23, 2022, 09:53:34 AM
Reading your post Royce "not right for your application" is that a ref to your pic(Holley)or his(autolite)? Is the throttle return spring available anywhere? Royce, is that return spring bracket at the base supposed to be "curved" up like that?
Corey's photo shows a Holley carburetor with an Autolite dash pot. The return spring bracket is available from Mansfield Mustang. Not sure which return spring Corey needs - it may be Shelby specific.
The 302 return springs are reproduced, however they are not correct. The GT 350 spring is not unique.
I am not sure which dashpot would be correct.
Quote from: Royce Peterson on February 23, 2022, 10:15:34 AM
My friend's car has the original spring return bracket. It was bent like a rounded  open "C". I straightened it out with some pliers Charles mentioned that worked great but that pic in Royce's post shows the bottom part of the bracket being curved. Should it be straight like the pic below that was sent to me by another member a few months ago? Thanks.
68gtcoupe
The return spring and return spring bracket on Corey's car are both original and correct for his application.  The items were removed from an unmolested 1968 J-Code 302.
Terry
Corey Bowcutt
By the way that sketch is from me.
Corey
