The restification of 1584-Cliff notes version
Started by Bill, January 21, 2018, 11:09:36 AM
With the crash of the forum, I started digging through old documents, and found quite a few pictures of the tear down and rebuilding of my 69 GT500 #1584. So I thought I would start a new thread, a shortened and cliff note type version:
So we will start with humble beginnings of how the car looked when I purchased it from our very own, world renowned "Shelby Hunter" Dominic D.
Now, it does not look that bad from 20 feet away, until you see a close up of the paint and previous bodywork
Then you get an idea of what I was going to be working with.
HOW TO IDENTIFY A FORUM TROLL
A trip to the media blaster, and some time being subjected to a series of crushed walnut shells propelled by a copious amount of air pressure, and what we thought would be a rusty chassis, thankfully didn't turn out that way. Two small areas of outer body rust were found, both on the passenger quarter panel.
David Hillman
Keep the photos and stories coming !  I never came across your original post so am looking forward to more !
#4
Being a March 31st 1969 build, I remember some arguments between  ;D "two members"  ;D  about whether the car came with the big (KKX) suspension (now documented as the earliest car to date thanks to Mongo), a space saver spare, and I think the ribbed drivers front inner fender panel. The big suspension was the easy one, the space saver spare took a little more time and muscle.
Yes to big suspension
No to space saver spare
Yes (I think  ;D ) to ribbed inner fender panel
Digging under the carpet found floors in beautiful condition, and three partial build sheets stuck to both the floor and the carpet underlayment
With a little computer wizardry assistance, a decent build sheet composite was created.
I was asked about paint stripping via PM, I chose to find someone who used crushed walnut shells to do the stripping as it was not supposed to do any damage to the body. While being stripped, I asked that the original fender stripes not be stripped off, both for the purpose of saving the original paint underneath, but because I was concerned that stripping that hard on the fiberglass would damage the front fenders.
After stripping, my paint tech rep and I spent several days mixing a modern day batch match for "Grabber Orange". Sometimes tinting the white base, sometimes not. Time and time again, over and over again. Differences in the mix down to 1/10th of a gram could make all the difference.
Quote from: Bill on January 24, 2018, 06:19:09 AM
If I remember right it was the space saver spare bracket . Whether it had a space saver spare or not was never in question  according to Mongo.
#10
Quote from: Bob Gaines on January 27, 2018, 06:49:01 PM
I believe you are right, and it started with me posting this picture..Maybe Ed will remember and chime in.  ;)
Couple of other random shots for this evening
Mongo
On the space saver bracket.  There has to be a point in time where non big spindles stop and and yet use up the inventory of F70x15 tires and big spindles come in and then the delete sheets reflect the introduction of the F60x15 tires and the space saver bracket came to be. Hertz cars good example introduced big and use up the old F60x15 tires. All stations at assembly plant are not up to speed at snap of your fingers. takes time to get all parts in place and add operations and changes to the assembly time procedures and instruct workers of change. "the rule of the assembly line formen is never stop the line from building units"!
"there has to be some kind of overlap or crossover when making" "production
run changes"!
ps FoMoCo is not going to throw out tires and spindles until they use them up!
mongo
Mongo
sorry meant to say Hertz cars for 1969 git the big spindles but used up the E70x15 tires.
mongo
I remember getting the car out one warm day and playing with my old shops 10,000PSI heated pressure washer, then thinking, maybe I went too far  ;D
