69 Brake rotors
Started by CHGOHR, March 23, 2022, 09:23:56 AM
CHGOHR
So has anyone found a solution for replacement front rotors for 69-70 shelbys?
68 GT500
69 GT350
72 Pantera pre L MSO
66 Tiger
65 K code (original owner Dad's)
Quote from: CHGOHR on March 23, 2022, 09:23:56 AM
It also has to do with big suspension or small. Two different rotors.
CHGOHR
My understanding is the 69 Shelbys had the same rotors as boss 429 and boss 302?
68 GT500
69 GT350
66 Tiger
No, not all 1969s had the larger bearing rotors you are describing.
There are two different sizes depending on when the car was built. The larger sized bearing type rotor is unavailable. You need to get creative to replace them.
All 68-73 mustang cougar torino etc  2 piece rotors are the same and can be switched around to the hubs and pressed off and back on. There are 4 different  hubs betweeen 68-70 as they have to match the spindles c80a  kkx doza-b doza-c
kasearch@ix.netcom.com
If anyone is needing a pair of NEW rotors for the 69 SHELBY or BOSS (not for regular mustangs), call Dan at 217-882-2083. He has a set available.
