Spindle ID Help
Started by brandosaac, March 24, 2022, 11:13:13 PM
brandosaac
I have a spindle that im trying to figure out what it belongs to.
It has a C9OJ-3107-C number on it and has the Kelsey Hays caliper bracket on it.
I thought this style bracket was only used on 65-67 applications??
any ideas?
Quote from: brandosaac on March 24, 2022, 11:13:13 PM
any ideas?
You thought right on the bracket only 65-67 used it. As you can see it will fit on a drum brake spindle . I haven't done it myself but others have used that combination because of availability on 65-67 Mustang disc brake conversions.
brandosaac
thanks, 'but do you know what the spindle itself is correct for?
It's a big bearing 1969 - 70 drum brake spindle.
Quote from: brandosaac on March 25, 2022, 11:51:39 AM
Quote from: Royce Peterson on March 25, 2022, 12:17:15 PM
That means it has the big hub also. You could do the "Big Ford" brake swap on those.
1109RWHP
Wouldn't the C9 part number make it a small bearing 69 spindle? I thought the 70 spindles used bigger bearings than 69?
Shelbypat
#7
Quote from: shelbydoug on March 25, 2022, 01:04:36 PM
No you can use 69 drum spindle to swap to 4 pistons caliper only
