68/69 brake rotors
Started by TLea, March 30, 2022, 06:13:57 AM
Looking for a pair of serviceable 6869 brake rotors small suspension . Must be able to turn within spec.
Also consider a pair of the now not produced two piece rotors that were made for a while
430dragpack
Do you happen to know what the minimum thickness is?  I have an original 69 set here that measure ~.864" and ~.872" that need turned.
TOBKOB
If I remember correctly it is .875...
TOB
1969 GT350 owned since 1970
TA Coupe
It is usually stamped on the rotor for minimum thickness.
         Roy
If it starts it's streetable.
Overkill is just enough.
