1969 GT350 AC Idler pulley finish
Started by SChatman, April 04, 2022, 10:39:04 PM
SChatman
Can somebody help me with what the finish is the adjustable Idler pulley?
Build date 1/9/1969. Also, is the site glass on the AC hose always built into the hose? I got a hose from Classic Auto Air and realized it didn't have the site glass.
Thank you
musclecarman15
Finish on both idler pulley setups( fixed and adjustable) is zinc phosphate for the bracket and pulley bearing cap, pulley is semi gloss black...please also note those brackets are specific to 1968-69 models,as 70 used the larger bearing. The fixed pulley setup has the letters SPC stamped on bracket and the pulley has a small S stamped on the pulley face,the adjustable pulley setup has the same pulley and bearing(5/8 by 1 3/8 by 7/16)...while it's bracket can have a large S stamped on flat face or have no markings at all on face.
Here is a picture of one in a FE AC kit boxed in 69
As you can see the hose with the sight glass incorporates the sight glass but it was from a different design than the assembly line installed AC's
Yes the sight glass section was "built into" the hose. Not the first time reproductions don't match the original design/details
Good thing is that there were a ton of lines made (shared with all Mustangs that came with AC)  so a decent original may be found with some effort
Quote from: SChatman on April 04, 2022, 10:39:04 PM
Thank you
Pulley is black somewhere between semi gloss and glossy . Bearing cover is zinc phosphate . The bracket is zinc phosphate. Yes the sight glass is made into the hose. Although functional All of the different classic auto air A/C hoses are a dead give away of a non original assemblyline hose. Even ford service hoses can be different. Hoses can be hard to come by so sometimes you have to make do.
SChatman
SChatman
Any suggestions on where to get a the best reproduction or an NOS hose with a site glass? Also, would an NOS hose be worthwhile as old as it would be?
Quote from: SChatman on April 05, 2022, 04:39:16 PM
When shopping be aware that NOS may not be designed or look like assembly line style. Like the one in one of my pictures and others I have , even in 69 the over the counter versions may have looked very different - with the larger site glass. Might want to look for a good original though depending on you caution level you might not to fully charge the system on a show car. Don't know anyone at the moment that is restamping the hose with the printing but the small hose labels are out there
