sw fuel pump
Started by tomhawk, April 07, 2022, 06:41:51 PM
tomhawk
For sale NOS sw fuel pump. The pump is NOS and  has a used bracket and rubber both excellent cond, Sell to lower 48 only. Checks or MO  I do not use pay pal. Will send the item in the pics. Asking 650.  Price drop to 600 plus shipping
CSX2259
Can you tell me what the numbers are on the wire? Thanking you in advance.
tomhawk
prestolite 3-71  m13486/1-5
CSX2259
3-71 is the manufacturers date code for the wire so you can assume the pump was built after that date.
Dan Case
#4
There should be a two digit manufacturing date code stamped on the main body.  This new old stock one is stamped D6. Based on what I found listed on the Internet:
D = 1960
6 = June
The wire connected to the switch is marked as being PACKARD brand dated 2-60 which I take to mean the wire was made in bulk from in February 1960.
If the main body was purchased as a repair part for an existing pump I would not expect an assembly date on it.
What is stamped on the main body of the pump you have for sale?
Dan Case
tomhawk
Dan Case
Quote from: tomhawk on April 08, 2022, 01:45:21 PM
stamped R-5
Thanks. 1972 May. Later than I am interested in.
Dan Case
