Forward under-ride traction bar mount welding
Started by kram350, May 19, 2018, 11:05:11 PM
kram350
About to weld the front mount. Does the weld run the entire perimeter of the bracket? Thanks in advance.
Quote from: kram350 on May 19, 2018, 11:05:11 PM
Typically stitch welded and not all the way around.
Hope these original examples help illustrate :)
kram350
Those pictures are great! Thanks for the replies!
#4
Hi Kram350,
Please tell me how you located the bracket.  Did you attached the axle mount and bar and located the brackets with the suspension fully loaded and then marked the location?  Then with the car on a lift, you can place the brackets and weld?
Vernon Estes
Some more pictures, these ones being off 6S1536..
Junk dealer and the oldest young guy you will ever know.
kram350
Let the car settle, swung the bar and mount into place under load, marked and welded mount on the lift and then reassembled. I followed the Traction Master instructions. Thanks for the photos .
