engine hood latch
Started by lawrence67, May 16, 2022, 01:08:37 PM
lawrence67
 GT-350 s/n 1935, SJ build 4/67,SA build 6/67.  Which of the hood latches would it most likely have been installed, long or short?  Hood all glass, no louvers.
Lawrence67,
Paul
short, see attached...
Also note correct hood hinge version..
and that late with all glass hood would have the Shelby smaller (diameter) hood springs...
lawrence67
rcgt350
Are you saying large diameter hood springs for early steel frame hoods?
Quote from: rcgt350 on May 18, 2022, 12:34:17 AM
Yes. the stock/standard Ford Mustang hood springs (larger diameter than the Shelby hood springs) were used on the early metal framed with fiberglass top hoods.
Quote from: JD on May 18, 2022, 08:31:12 AM
To add - the reason is the larger diameter stock springs were needed to hold up the heavier steel inner structure early hood. The small diameter lower tension springs are not adequate to handle the weight and consistently hold the early hood up.
