2006 GTH "Under tray" or "Splash sheild" parts
Started by 66dave284, May 18, 2022, 01:22:23 PM
66dave284
Screwed up front facia (it is ok I can fix it) but the air deflector/underside splash shield for 2006 GTH.  Would sure appreciate anyone with any info on where I might search or find the parts.  Thanks,  Dave W. (dwalters72@gmail.com)
Are you looking for the plastic pieces on the under side?
Call or visit your local ford dealership tell the you need the parts for a California special mustang
They do not understand what a GTH is
HERTZ II
Quote from: 66dave284 on May 18, 2022, 01:22:23 PM
I believe the part you are referring to is the plastic "belly pan", (Ford Pt #5R3Z-17626-BA). However, you said there's damage to the front facia so you may also need the plastic "filler" (Ford Pt #7R3Z-17C947-AA).  The filler attaches to the bottom of the front facia and provides the mounting surface to which the front of the belly pan attaches.
66dave284
Great info .... sure appreciate the part numbers.  Local Ford guy was in the dark until I told him they were the same parts as on the California Special.  Got them on order ....... Thanks !!!!!  Dave W
