Wanted: 289 HiPo heads, Dated June, July, August 1966
Started by roddster, May 27, 2022, 07:04:17 PM
  Like it says, if you want to sell them, PM me.  I will pick them up at SAAC 47 -Indy.
Bare, used, just not cracked or otherwise useless.  Thanks, Rod T
  Thanks but I read the ad and the seller does not want to deal with any shipping issues.  It would have been nice to put my hands on them at SAAC 47.  Not to worry.  I'm still looking and still have the car.
Harris Speedster
Head repair,
An external bolt hole is a pretty easy fix for a machine shop.
Many shops weld and repair cast iron daily.
This head could be bolted onto a block and welded, keeps any warping to almost zero
There are other alternative repair methods also.
John
     I agree that 'most likely' this bolt hole boss could be repaired; and the proper process would be via cast iron welding.
     But never use the word "easy" when the process of welding involves cast iron, as at times one encounters difficulties with the parent material being awfully dirty, this even often being the reason for the failure in the first place (though perhaps not here  :-\ ), and even with experience and good technique this material can just refuse to cooperate.   :o
     In this repair requirement presented, bolting the head to an alignment fixture, which is often good practice, I would not would deem required here; this as the sum of material and surface area and therefore critical heat levels to the overall casting is not relatively great and considering its' proximity in relation to the whole of the casting excessive shrinkage draw should prove minimal.  But more material and a greater involvement may be required to resist heat-effected zone cracking so things might change!
     But do be aware that excessive heating of any complex fixture with inherent stresses will cause movement, whether they be due to newly created stress loads or relaxation of previously imparted and that all critical machined surfaces will require (well, at least advised!  ::) ) re-working post a welding operation.   :)
  Bump.  It's been a while.  Spare me the "needs work" type heads, eh.
