shock tower (cap) question
Started by hurlbird, June 14, 2022, 08:51:01 AM
hurlbird
For my 70 MACH 1. The "towers" where the front shock bolt into i need to replace as i have lovely chrome reproduction ones  :-[ Is there a proper part number for the factory tower caps? this is just the top piece that accepts the shock bots. Thanks
Quote from: Bob Gaines on June 14, 2022, 10:36:55 AM
Quote from: hurlbird on June 14, 2022, 09:30:34 AM
great and thanks
Keep in mind you will have to weld on the reinforcement washers to your donor "beehive" caps to make them look factory . Unlike other years (66/67 in particular) where there were sporadic times in production when the heavy duty caps were not used for whatever reason 69/70 typically had them throughout production. They would be painted black when reinforced unlike the typical zinc phosphate Dearborn caps.
Pretty sure a Mach One is not a Shelby Bob.
Quote from: Royce Peterson on June 14, 2022, 10:48:43 AM
great and thanks
Thanks for the catch. I was on Shelby auto pilot .
hurlbird
does that change anything? same part?
Quote from: hurlbird on June 14, 2022, 12:17:00 PM
The shelbys had washers welded to them. Depending on your plant the caps could be painted or phosphate. Dearborn phos, Metuchin and SJ   painted. Shelbys are also painted-see pic below for washer ref.
hurlbird
thanks. also a very clear part number can be seen.
Quote from: hurlbird on June 14, 2022, 01:24:27 PM
In my photo above that is my car's Vin. Mandatory when it sold new in Belgium in 1970
