67 9" rear carrier assembly
Started by Brandon, June 26, 2022, 03:46:11 PM
Brandon
Looking for a clean 67 9" carrier assembly.
1175
Center section only?
Preferred date?
Jon
Brandon
Yes on center section only.
Assume they're all coded C4AW 4025-B, open to date codes, but preferably want one that's plausible for the car.
Quote from: Brandon on June 26, 2022, 03:46:11 PM
Is your car a GT350 or a GT500?
Auto or 4-speed?  (Do you want the original rear gear ratio or something different?)
Do you know the San Jose build date?
tgilliam
Scode67FB,
I sent you a PM.
Tom Gilliam
tom@jtgil.com
Brandon
Quote from: JD on June 28, 2022, 06:29:56 AM
GT500
4-speed
Prefer 3.89
San Jose build date January 67
Quote from: Brandon on June 28, 2022, 11:44:40 PM
GT500
4-speed
Prefer 3.89
Just in case it matters to you your GT 500 would have had a spec case from the factory.
Brandon
By spec case do you mean special in some way?  Or are you talking about the gears?
Bob is referring to the letters "SPEC" being cast into the outside of the housing.  will look for an image...
see attached,
