68 Air Conditioning Conderser
Started by shelbydoug, August 12, 2022, 05:20:16 PM
Was the condenser as factory installed painted black or was it left natural aluminum as manufactured finish?
Thank you.
The original part number should be ink stamped on it?
Quote from: shelbydoug on August 12, 2022, 07:09:32 PM
Thank you.
Don't recall or have any examples with any ink or paper labels on one. Driers had a uncoated paper label with the part number and arrow for flow direction and a stamped/added date stamp applied over the preprinted label. They often did not hold up well exposed to the elements behind the grill
Quote from: J_Speegle on August 12, 2022, 07:50:00 PM
Thank you.
+1 not typically a ink stamp on the condenser.
lockfish
The drier on my '68 GT500 has a paper label with part number C60Z-19959-B (see attached picture), but no apparent date code.  Is this part number correct for '68?  If so, where can I get it refurbished.  Thanks
68blk500c
My 500 did have an ink stamping, which was saved.  I will find a picture and post.
White ink stamping on the top surface (when mounted) near the RH corner, oriented to be read from engine compartment.  Pretty obvious it is a date.  Is visible from the grill area with hood open.
68blk500c
The paper label on the dryer tank should be C7ZA-B, with date stamp.
Quote from: lockfish on December 06, 2022, 01:40:53 PM
Interesting label. Don't recall ever seeing one with a black boarder around the outer edges.
68blk500c
Jeff:
None of the reproduction labels available at the time of our restoration were deemed to be factory correct, based upon my research of 1968 Metuchen original cars.  You have done an enormous amount of research on many original details, so I am open to input.
Respectfully, Don
68blk500c
Despite the picture quality due to location of the label, there is NOT a black margin around the label.  Trust me, Jeff.
Don,Jeff post refers to the picture Lockfish posted not yours. Look at the quote in Jeffs post that he was replying too. Easy mistake to make.
Quote from: 68blk500c on December 06, 2022, 03:26:22 PM
Picture I was referring to. That is what I felt was unusual or different from  the ones we typically see without that detail
lockfish
Thanks for the feedback.  Now the question is, where can I find a correct drier replacement or get the one I have reconditioned?  Also, I would like to know if anyone reproduces the manufacturer tags for AC compressors.  Thanks again.
Quote from: lockfish on December 06, 2022, 05:32:08 PM
Only service replacement style dryer that is different then assemblyline is available new. You can get your dryer rebuilt if the core is good . Rebuilding is a hefty sum compared to the service replacement . It just depends on your expectations. ECS makes the dryer stickers. triangle compressor tags are reproed but the rectangular ID plates for the compressor are hard to get.
