'69 Trunk Q
Started by Survivor, August 26, 2022, 09:20:59 AM
Survivor
Did the '69 spare have a plain jane rim or a five spoke and what would the tire have been.  I'm assuming it came with the air cannister.  Thx.
You need Coralsnake help 😎
www.thecoralsnake.com/69tires
See the bottom of the page
Quote from: Survivor on August 26, 2022, 09:20:59 AM
Since the excellent information in the  www.thecoralsnake.com/69tires  website did not completely answer your question I will give confirmation that spacesaver installed was a plain steel rim . I hope Pete will add the addition of this tidbit as I have been asked many times about the same question given illustrations on some jacking instruction stickers. Also earlier pre late March cars did not typically come with a bottle cradle and later cars did.
I would be happy to add that information to the page.
Would I be correct in saying it is the 14x6 disc brake steel wheel?
Quote from: Coralsnake on August 26, 2022, 11:27:56 AM
Most likely but I am not for sure that if in 69 the standard 14" steel wheel is different between disc and drum.
I can take a picture of my original one in my GT350 if you like. I know it isn't a dist pic but it's the best I can do at home.  ;D
honker
Here's what I have noted as a '69 ?  GT350 trunk in my files, not sure if this is original or restored ? I believe these images where
on forum 1 ? ?
Mike
FYI the yellow sticker in not concours correct if that matters. That is because they were not available at the time of the MFG or even a couple years after. They were sent to Shelby owners as part of a recall starting in around 1971. I have a letter from Ford including the sticker asking to immediately apply to wheel. Dealers were probably asked to apply them as well just like the caution fan stickers. It is only a small minority of 7.35 space savers that I ever see for sale have them applied. I have not seen a survivor car yet that has had one applied not to say a survivor owner could not have received the letter and applied the enclosed sticker but that out the many survivors that I have seen none have had the sticker applied. I have however seen a couple where the sticker was loose . Apparently a sticker was received and rather then apply it the owner tossed it in with the space saver.
Quote from: Bob Gaines on August 26, 2022, 03:27:01 PM
Valve stem is also incorrect. I see them on later space savers.
honker
Thanks guys ! as always a reply detailed and informative.
Mike
Quote from: shelbymann1970 on August 26, 2022, 03:30:30 PM
Good eyes Gary. I missed what I call the double valve stem . Those later 70's space saver's are the ones that the stickers were applied to at the factory . I cant tell in the picture the size but the majority of those with the double valve stem had a F 78 14 sized tire too.
Quote from: Bob Gaines on August 26, 2022, 03:53:18 PM
easy to miss as the sticker blinds you.  :D
original parts. I added the sticker over 20 years ago(no witness of having the sticker before).
Survivor
Could someone enlighten me as to the '69 date code 9ME w/ respect to an original BF spare tire.  Thx.
Quote from: Survivor on September 01, 2022, 10:16:30 AM
I have original wheels-69 Mach1 chrome wheels where I see the same thing stamped. I'm sure that 9ME isn't a date code per year/month/week so to speak. That spare is the original to a May 6th 1969 Dearborn car. I can pull the wheel out for further inspection.
