1967 Shelby Rear Fender End Caps
Started by nightmist67, June 07, 2018, 02:27:04 PM
nightmist67
How can one determine if the fiberglass rear fender end caps on a 1967 Shelby are original or reproduction?
Quote from: nightmist67 on June 07, 2018, 02:27:04 PM
Typically the repros have mounting studs. Not all however which complicates things . There are other tells in how they are mounted.
nightmist67
Is/Are there any source(s) from whom a pair of original 1967 Shelby rear fender end caps could be obtained?
DC-DD
nightmist67
Dominic -
Thank you.  I sent you two PMs.
Bossbill
Aren't there different version of these?
I have a hybrid steel/fiberglass rear deck lid and the end caps melded into the decklid in one smooth concave curve. The Lime Gold car ad with the pretty lady admiring it at the rear appeared to have this version.
Some all-glass decklids appear to go from a smooth concave curve to almost straight up and down at the sides of the lid where they meet the cap. The caps appear to have this same feature.
I've also seen caps that match to the rear taillight panel on the inside curve. This appears to be mostly on the flat and early taillight panel.
Other caps are much squarer on this inside curve that may match other taillight panels.
Lastly I have a few caps with the molded in S7MS part numbers.
70 B302   6/6/70  0T02G160xxx
Fast Fords
The caps on my car have the S7MS part number on them. I also have another pair with no number but I don't know if they are original ones or repro ones. Not sure how to identify originals without numbers.
You typically have identify original end caps by the back side mounting characteristics. Many times the engineering numbers get sanded off the first time the car is repainted or fixed after a accident let alone the second and maybe third time it is done after 50 years.
The "originals" were made by more than just one supplier, so variations exist.  Attaching method is a big sign as to the likelihood of an original.
Also, early cars had one exterior screw at the very bottom of the "tail", later cars had three exterior screws, bottom, middle and top of the "tail".
Bossbill
The Shelby Assembly manual is vague on the type (pan, oval,?) and finish of those 3 screws.
Any help there?
texas swede
I have noticed that some 67's including my car, #1317, have an uneven angle towards the middle of the car
on the passenger side end cap. The lower inner corner sits lower than the trunk lid and the driver side end cap.
Texas Swede
nightmist67
I recently had the opportunity to look at #1169, which reportedly is a one owner unrestored car.  It has end caps with studs and washer and nut fasteners similar my car, #916.  Neither car shows evidence of rear end damage that would have required replacing the end caps.  Comments?
Quote from: nightmist67 on August 15, 2018, 02:54:40 PM
Not typical.
Quote from: Bossbill on July 06, 2018, 04:32:31 PM
Any help there?
Since I just saw it and it hasn't been answered the screws were pan head Philips P/O finish.
My Shelby has U nuts on flanges with 1/2 hex head  5/16 thread. It also has a tar sealer around the bolt heads.
