Need help with tach identification
Started by daltondavid, October 06, 2022, 09:42:28 PM
daltondavid
I have this Smiths 7000 rpm Tachometer and am curious if it is correct for a 2000 series Cobra. And if it is, any idea on a value? Any insight appreciated!
Cobrabob
No, that is not a 2000-series Cobra tach. They did not have the red zone on the face, in my experience.
Had one identical to that in a modified 74 Pantera back in 1984, but not 100% certain my dash gauges were stock.
HOW TO IDENTIFY A FORUM TROLL
Dan Case
The Smiths brand street Cobra tachometer was a higher rpm range and mechanically driven by a cable from the Lucas brand generator.
Dan Case
daltondavid
shelbyluva
Hey Dan, would the one pictured in your post have been the only tach used until the Rotunda was worked into the mix in the 21xx range?
Dan Case
Quote from: shelbyluva on October 29, 2022, 11:38:29 AM
That was the mechanically cable driven off the rear of the Lucas® generator tachometer model that A.C. Cars installed. The electrically operated Ford-Rotunda tachometer with dash hole size reduction adapter was introduced when HP289 engines, Ford voltage regulators, and Ford HP289 generators with machined from bar stock sheaves were introduced and that happened as the new specification in the CSX207x range production wise.
Lucas® brand generator with an A.C. Cars designed and provided one piece cast aluminum large diameter fan and sheave
Lucas generator, A.C. Cars sheave, Lucas gear drive adapter, and cable leading to under dash.
Dan Case
CSX2259
The Smiths tach was driven mechanically by a cable and a gearbox off of the back of the Lucas generator as Dan indicated. Here is what the gearbox looked like....
