1970 427 Boss 302
Started by deathsled, October 13, 2022, 08:31:50 AM
nctrucks
Here is some more clear pictures My Boss 302 with 427 sideoiler stroked to 482ci  Just about finished.
Whoooodogie that's a nice ride  !
Marcus Aurelius
Our Pronouns are We Won
Bring on the tariffs
Usque Ad Finem
deathsled
Quote from: nctrucks on October 14, 2022, 12:03:35 AM
Will go like the wind I would imagine
Engine revving to disturb
Drew Pojedinec
I just did a set of BU/BT dual 780cfm carbs for a member here who has a 427 medium riser in a Boss car.
Quote from: deathsled on October 13, 2022, 09:54:41 AM
You're welcome. I was astounded that the shock towers would accommodate such an engine. I thought they had to be cut at the factory when a customer ordered the 428. Seemingly not. One size fit all. Also surprising that a G.T. 500 owner gave up this engine to put a K code 289 in his 500. Times were different then.
Look at the 429 vs a 428. The 428 has the towers, the 429 does not
Marcus Aurelius
Usque Ad Finem
mikeh
Very cool, that's my kind of ride!!
rhjanes
FL SAAC, I'd phrase that as "The Boss 429 has SHAVED shock towers".  They weren't totally removed.
nctrucks
Drew Pojedinec did a fabulous job restoring the set of BU/BT dual 780cfm carbs for this project and my original 1967 GT350 carb.
JohnSlack
Quote from: rhjanes on October 14, 2022, 10:13:55 AM
Actually the BOSS 429 shock towers were a completely different stamping and were installed on  the assembly line at Kar Kraft. The BOSS 429 is a great story. If you are really not educated on the whole process it is worth being educated on.
John
QuoteActually the BOSS 429 shock towers were a completely different stamping and were installed on  the assembly line at Kar Kraft. The BOSS 429 is a great story.
Hmmm, where can I find this information? I thought they were installed by Ford.
JohnSlack
Quote from: Wedgeman on October 13, 2022, 12:33:00 PM
There is still time...John Slack... ;D   ( Go with the Stroked Tunnel Port).... ::)
Wedgie,
Unfortunately after collecting an NOS 427, having acquired two pairs of Tunnel port heads, one NOS set, one set from Bill Ireland, a single Dominat or intake, and a Dual plane 2x4 Tunnel Port intake manifold. I started down the Dual Dominator BOSS 302 TA intake manifold rabbit hole. That trip took me to the end of the internet and back, eating all of my FE parts collection in the meantime. I'm quite sure that if I started down the 427 rabbit hole again when I came back out my house, my wife, daughter and cat would be gone when I came back out. However I will say that every time I see your car my heart skips a beat accordingly.
John
JohnSlack
Quote from: Coralsnake on October 14, 2022, 02:34:40 PM
Possibly, I know that some of the early cars left Dearborn with 428 engines as mule motors. The shock towers were a different stamping and as you say and as I say we're installed by FoMoCo whether at Dearborn or Kar Kraft I don't know.
Honesty, I dont know. I was under the impression that Ford installed the shock towers in the cars....off to find out! 🤔
Well that took two minutes to figure out. Boss 429 shock towers were done at the Dearborn assembly plant by Ford employees. Thank you for the opportunity to clarify that for people who care about the facts.
JohnSlack
It is interesting to note that the BOSS 429; will bolt directly into the 1971 Mustangs without modification.
John
