ancillary fuse board
Started by Jack4159, October 24, 2022, 11:39:00 AM
Jack4159
This is the "extras" fuse panel that attaches to the fuse box under the dash.
When I pulled it out I noticed that the wires coming off one of the fuses were not connected to anything and I forgot to take notes or pics of where the other ran to.
I think a 25amp runs from this panel to the aircon, is this correct?
My second fuse is also 25amp but as I said, went nowhere...
Should there be a second fuse on this panel? Should it be 10 amp and to the fog lights?
Thanks as always  :)
It sounds like you might be referring to the circuit breakers for the AC and fog lamps?
It is a bracket mounted behind the fuse panel
Jack4159
Thanks Pete my bad yeah circuit breakers not fuses, wasn't sure if the second one was for fog lamps or not, thanks for confirming.
There are two on a AC car, one is for fog lamps
