'69 Carb
Started by Survivor, October 31, 2022, 09:52:50 AM
Survivor
What would the correct carb. be for a '69 350 auto.  Thx.
Just in case we need it to answer. AC or non-AC?
in either case it will be an Autolite 4300 with automatic choke
Survivor
I believe its the C9ZF-9510-D
Its a pretty common carb, dont pay a lot for it
Survivor
Thanks for the info.
Couldn't find in my pictures any examples where the car was a AC car and the tag was legible but here are a few to help guide you to what the style of carb is to help with the hunt
Please ignore the aftermarket spark plug wires
TA Coupe
I have one that looks exactly like those that came off of a 69 Mustang with auto and AC. The carb tag broke off so I don't know the exact numbers on it you can see in the picture where part of it is still left underneath one of the screws.. It will need to go to drew for rebuilding.
          Roy
If it starts it's streetable.
Overkill is just enough.
The number should also be stamped on the foot of the base
To help illustrate and locate here is an example of the stamping for a C9ZF-C
TA Coupe
The only number I could find was a very tiny number 2 on the side of the base plate.
        Roy
