How to test Tachs 67/68 Ford Mustang and Shelby?
Started by Kent, November 03, 2022, 03:59:51 PM
Kent
I´m still thinking about how I can test my tachs here. I have a 65 Mustang here with no tach and would like to use this engine as the bench. So would it be ok to take a 1.5 ohm ballast resistor between and put it in line with the ignition switch to coil +
I read on some other forums that some people don't use a ballast resistor and only put the tach in line from ignition switch to coil +
Is there maybe a drawing or something how to do it right, thanks...
67350#1242
Even non tach cars have the resistor wire in line from ignition to coil.  You should be safe putting the tach in series with that circuit.
67 GT350
I have a diagram from Phil Severance for the Shelby tach for a 66, would you like that?
RARE  Signature Delete
Kent
I think that could help, you have my e mail from last week I think, thank you.
67 GT350
