Jack Bungee Cord Clamps
Started by PaulD, June 14, 2018, 10:36:57 AM
PaulD
My 65 has the clamps for the jack bungee cord riveted directly to the floor. I have seen pictures of restored cars that show the clamps riveted through the trunk mat. What is considered correct? On a related note is the number on the bottom of the mat a date code? Can any one decipher "55 C922"?
Paul
Brant
Quote from: PaulD on June 14, 2018, 10:36:57 AM
Paul
Paul,
Most all originals that I have seen, including 5S162, have them riveted on top of the trunk mat.
-Brant
Quote from: Brant on June 14, 2018, 01:30:09 PM
Paul,
+1. riveted through trunk mat is most typical.
sfm5s081
Does one know where I can buy the bungee or the clamps?
The clamps are the same ones used for the front to rear battery cable attaching to the chassis.  Brant should have them.
sfm5s081
Quote from: caspian65 on June 18, 2018, 11:25:23 PM
So I'm assuming there are 2? One on the top, one on the bottom? How far apart should they be and any idea of the cord?
NC TRACKRAT
Look closely at the picture.  You can see both ends of the bungee cord. There is only one clamp.  Seems I recall a discussion on the old forum where there were a few cars with two clamps but most only had one.
p.s.: We ascertained that the early cars had no clamp/s.
5S071, 6S1467
sfm5s081
So it was pointed out by Howard Pardee that the early Cars, had trunk mounted batteries and therefore no clamp as it would have gotten in the way! Duh! Therefore the jack and handle should be in the wheel well?
Quote from: sfm5s081 on June 26, 2018, 03:55:37 PM
The clamps mounted in one of the typical locations with the jack stowed do not interfere with a trunk mount battery.
Quote from: Bob Gaines on June 26, 2018, 04:12:23 PM
Just to be clear I agree some early rear battery cars did not have the clips riveted to the floor to hold the jack and the handle/handles. I don't believe all were done that way without .
Quote from: Bob Gaines on June 26, 2018, 04:25:24 PM
+1 :)
Brant
Quote from: NC TRACKRAT on June 19, 2018, 05:13:10 PM
Stan,
No, there are two.
-Brant
NC TRACKRAT
O.K. Brant...Then what's going on in the picture?  I clearly see two bungee cord ends around the one clamp.  Since we don't have the benefit of going back to the old forum, we only have our memories.  I know mine is failing but I do seem to remember the discussion that some had only one clamp and some had two.
5S071, 6S1467
Quote from: NC TRACKRAT on June 28, 2018, 07:47:16 AM
Look at reply #8 . The clamp goes around and holds the bungee cord. The cord wraps around the jack and is secured to the clamp farthest forward. Brant's picture appears to be the same.
sfm5s081
Almost there....
http://www.virginiaclassicmustang.com/65-GT350-Battery-Cable-Bungee-Cord-Clamp-P482363.aspx
Any indea when you might have some more Brant? I'll take a set for sure.
