California License Plate Service
Started by SHELB66, December 01, 2022, 02:59:05 PM
SHELB66
I used this gentleman's services to have my white, personalized Calif. license plates switched over to the black/yellow style plates from the 60's.  This color style plate was not available from the DMV when I originally ordered my plates. It is now available and is known as a Legacy plate.  They are nice plates but the font for CALIFORNIA is not quite the same as the originals.  I decided to have mine redone using this service and am very, very pleased with the results.  The font is correct and they look just as if they've been repainted.  Coloring is spot on.  The work is outstanding!  Fortunately my plates were in excellent condition to begin with which makes the process easier.  He is unable to do any out-of-state plates due to lack of appropriate software.  Just thought I would pass this on in case anyone with Calif. plates is interested.  One can contact him for info regarding his services.
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
02 Explorer Sport Trac
greekz
An innovative alternative.  Is the California raised or flat on the plate, cannot tell from the picture?
Also, I thought I read somewhere long ago that is was illegal to alter a California license plate.
SFM 6S1134  '67 GT-350 #2339
Marcus Aurelius
Our Pronouns are We Won
Bring on the tariffs
Usque Ad Finem
Quote from: greekz on December 01, 2022, 03:25:49 PM
Since it a simple vinyl wrap that area is flat like the base license plate
Quote from: greekz on December 01, 2022, 03:25:49 PMAlso, I thought I read somewhere long ago that is was illegal to alter a California license plate.
Yes it is. Would guess that the biz makes the claim or warning (if not they should) that the plates are for display purposes only
greekz
Quote from: J_Speegle on December 01, 2022, 05:00:16 PM
I thought so.   That is why I have not had my blue and yellow personalized plates painted black and yellow.  The authorities probably would confiscate them.
Alter/cover/repaint/etc all carry a fine. The judges figure any altered plate was done for criminal purposes and fine accordingly. "Restoration" of plates is legal - that said to use YOM (year of manufacture) plate you need to submit the plates to DMV. They will authenticate that you have 2, they are real, the correct year for the car, in a condition they approve of, a number not currently in use and the right colors. My 29 Model A came with a pair of restored plates. I registered the car with them and still have about 60 days on the 90 DMV said approval would take. These things are so heavy I think they affect the mileage - not the current thin aluminum stampings.
Side-Oilers
#7
^^^ Brett, I agree. My experiences have been the same.  But, I've also had good luck with having vintage-style repro plates made (FOR DISPLAY PURPOSES ONLY) and getting them "DISPLAYED" on my car.
The key is to get the repros made from original type (heavy) steel plates...not aluminum...for your DISPLAY.  Much more accurate.
The right era plates just look so good on a classic car.  Just another detail touch for those of us who like such things.
Because I grew up in CA,  my memory is full of esoterica like CA license number sequences, and the year that they would've been issued.  I always want to be sure the ones I'm buying would've been in the range of plates distributed by the DMV for the year/month my car was originally sold.
For instance:  The CA DMV doesn't seem to care if you put a ZZZ plate on a 1964 car, which would've originally had M, N or O as the first letter in its sequence, but I wouldn't do it.  I can spot those mistakes from a mile away.  Makes the "perfect" car look weirdly off.
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
Quote from: Side-Oilers on December 01, 2022, 10:49:46 PM
It is my understanding that in the past that it is illegal to make license plates out of steel and is one of the main reasons they are made of aluminum. Has that changed?
Side-Oilers
#9
Hi Bob,
I never heard anything about it being illegal to use steel.  CA changed from steel to aluminum sometime in the early '80s, IIRC.
I do know that anyone wanting to have an authentic set of vintage CA plates made FOR DISPLAY ONLY should use steel for the 1963-69 black-and-yellow plates, and the 1970-?? six-digit blue-and-yellow plates.
I seem to recall that it was when the seven-digit CA plates came out (1979?) that they changed to aluminum, but I could be off on that date.
Van
Current:
Previous:
1957 T-Bird E-model
pchmotoho
Quote from: SHELB66 on December 01, 2022, 02:59:05 PM
Craig R.
on the newer plates California is spelled out about 3/4 inch longer than it was on the original black plates.  The first versions of the blue on yellow plates also had a shorter version of California as well.  It didn't last long and was changed over to the length that you will now see on the Legacy plates.
TA Coupe
Mine are like the SHELBY ones above.
I had them done about 23/25 years ago. If I remember correctly it was done through an ad in Hemmings.I think the place was in Florida but I would have to look through my paper work to verify.
         Roy
If it starts it's streetable.
Overkill is just enough.
