Rear brake drum swap
Started by Shawn, December 03, 2022, 12:14:06 PM
Shawn
I have a 1969 9" rear with 10x1/34 drums.  Can I swap them out for 10x2" drums?  Will the backing plate accept this change?
Quote from: Shawn on December 03, 2022, 12:14:06 PM
Why would you want to and risk clearance issues with the backing plate? It is not like you can add 2"shoes to the stock backing plates for more braking. They commomly available aftermarket or the 10X 1 3/4 was on over a million cars over the years so there are still a lot of donor application options still available.
jamesfee
Shawn,
IDK about the backing plate/drum change (I've got a '66) but if you are looking for a driveability work-around I would look into some of the more aggressive friction compounds. I'm running Porterfield's R-4 compound but I'm sure there are several other brands as well that will give you better braking with the setup you already have. Just a thought.
j
6S1801
Shawn
I guess what I'm asking is can the original backing plates stay and use 2" drums?  The 1 3/4 drums are trash and was just looking into using the 2" if possible. Also the rear is a 1967  not 1969
jamesfee
Shawn,
If that's the case, I would see your local parts house guy/girl. FWIW the Rock Auto site lists a 10x2 drum for that year. I would have thought the 390's came with the bigger size - but you need a reliable way to research that.
jim
6S1801
Quote from: jamesfee on December 04, 2022, 01:29:51 PM
Shawn,
jim
Both 67 and 69 390 or even 428 Mustang used 1 3/4 shoes from the factory
jamesfee
Thanks for that insight Bob.
j
6S1801
Shawn
Thanks All - I may have posted a bit early before taking accurate measurements.  I do have 2" brakes on backing plates 71805 and 71806.  Anyone know what the application make and model they are used on?
Appreciate your correspondence
Kind Regards
Shawn
