front fender lower section
Started by Dennis Y, December 04, 2022, 11:29:26 AM
Dennis Y
Has anyone used the above mentioned item from Branda and if so what's your thoughts on fit and finish?
Thanks!
Shelbypat
Hi.
I have used both lower section and front valence from branda so they fit well . if you keep using your original front valence it might be an other story.
Patrick
Quote from: Shelbypat on December 04, 2022, 06:42:24 PM
Hi.
Patrick
Does the back side still have a rough fiberglass texture different from original? That was the way the back side of the lower fender piece and back side of the front valance were the last time I saw one but that has been a few years ago.
Shelbypat
Mine's restauration has already 18 year old. Yes the inside is hairy style fiberglass.
A few years ago I learn from a previews post that the inside was suppose to be black. So I take it off, sand it, used the occasion to remove the rough with corners sections and repainted as it should be.
Patrick
Quote from: Shelbypat on December 04, 2022, 07:59:35 PM
Patrick
From Just a small portion of the backside of the fenders is black . Just a small area and then some additional over spray . A little bit more of the backside of the front valance is blacked out but not even that is completely black.
Dennis Y
Were the original lower pieces smooth white on the back side or is this a replacement panel?
Original FRP (Fiberglas reinforced plastic) was a variety of colors. White and pink were the  most common.
Quote from: Dennis Y on December 07, 2022, 12:57:31 PM
Even though the substantial repair work is substandard the base white material appears original.
Dennis Y
Hey Bob, sub-standard is being kind but then I realize that the person that did that work quite possibly did this to the car also unless it was the owner before him who did the damage. As I have said before, I'm pretty sure it was a 1320 dancer early in it's life.
