Holley Carb #4168
Started by 7777kx, December 14, 2022, 06:09:17 AM
7777kx
Would any forum user know the Holley part number of the electric choke pull off system, when originally fitted to this carb.
I need one to replace the manual choke assembly currently installed.
Any help much appreciated, thanks Alan
You use the word "originally"
This carb did not originally have an electric choke
Drew Pojedinec
Std Auto choke and cap. I've seen GTA and GTI caps on them.
Choke plunger is the typical two piece unit found on my cobrajet stuff.
7777kx
Hello Guys, many thanks for the information.
I am sorry, i gave you wrong information.......the choke pull of is via the heat rise tubes from the manifold, not electric. My sincere apologies about my error.
What i need is to convert the manual choke opertion to one which works from the heat riser tubes, anybody have one to sell or know the part number of a replacement?
Thanks again
Alan.
Harris Speedster
You are working on a 1968 Shelby?
You say >> autolite carb in first post.
Then you say you want a part number for a Holley auto chock assembly.
I am confused.
I do have a complete automatic chock  assembly that bolts onto a holley
I do not have one that bolts up to a Autolite.
John
