428 camshaft selection, part II
Started by roddster, December 20, 2022, 05:46:55 PM
 12/20/2022
  Recall that post from back in August of this year about cams for a 428?
Just last Saturday I received the special ground hydraulic roller camshaft for my 428 CJ build.  It is going into my 67 Tribute car.
    I used Brent Lykins motorsports to order the cam.  He must have ordered it through Competition cams as that is the box it came in.  Street grind with hydraulic roller lifters.
  Ordered it back in August.  And it seems there were no cam "blanks" to be had.  This is why the extra time was required.  Happy building is about to start.
aj
Have used Lykins Motorsprts several times for custom cams ( FE and Boss 302).  Brent very knowledgable with lots of dyno experience.   Good vendor
It appears that all of the FE profiles offered by Comp Cams are "back ordered" according to their web page.
I would cross reference the cam number that you got to verify it is not an "off the shelf profile" from them.
There are some stockish CJ like profiles the consider stock.
crossboss
IF you go old school, the Ford performance hyd 'C' cam is an excellent choice.
Past owned Shelby's:
1968 GT-350--Gold
Current lifelong projects:
1968/70 Olds 442 W-30
Quote from: aj on December 24, 2022, 08:36:20 AM
   Good idea.  I double checked and the Brent Lykins grind is special and custom.  Nothing in the catalog matched it.
Quote from: crossboss on December 25, 2022, 03:49:27 PM
I have used that cam in quite a few fe  builds and always was happy with it .
