Engine on Bring A Trailer
Started by Poor Ron, February 10, 2023, 07:20:21 PM
Side-Oilers
Brett, what happened with the Pantera project?  Power, speed, etc?
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
Quote from: Side-Oilers on February 12, 2023, 06:28:34 PM
Trailer queen show car - I don't think anyone has driven it at any speed lest they ding up the polished aluminum inner wheel wells - it did sound good though. It was kinda Cammer meets turbine with the short pipes off the turbos.
OldFordGuy
Came here to post this. I knew this would be expensive, but WOW! $65k with 2 days left. Sure would like to see what it ends up going into, or do you put it in a car, ever?
1963 Galaxie 427 R code
1965 Mercury Park Lane Super Marauder convertible
Coming soon: OldFordStuff.com
deathsled
Engine revving to disturb
Quote from: 98SVT - was 06GT on February 12, 2023, 08:33:43 PM
Are you talking about this one ?
Don't know how functional it is, but boy it sure looks purteeeeeeee
Marcus Aurelius
Our pronouns are We Won
"Usque Ad finem"
Quote from: FL SAAC on February 16, 2023, 10:38:06 AM
That one looks like it has different flares. Those look like the regular Group 5 flares and Megabuck had ones that looked similar but were a couple inches wider - they were hand formed out of steel and hammer welded to the body so you didn't see a seam. I couldn't see someone tossing out the aluminum inner panels either - they were a work of art. There was also a polished full belly pan and polished aluminum inner wheel wells. Last I heard the car was in a private collection in the Carolinas. Dennis (the builder) loved it whenever it changed hands whoever bought it would send it to him to be freshened. Everyone wanted it running but no one seemed willing to drive it. George Stauffer owned it at one time and he pulled out the custom nixie tube gauges (that never worked right) and put in normal gauges. The wiring on the car was a nightmare - it was all red with no coding/tracers on them. I had a couple hundred pictures I took while it was being built. Dennis brokered a deal to sell them to one of the owners - I should have made an extra set of prints there were lots of little details. I think I still have some of the Rossa Carrera red lacquer that was ordered from Italy by the local Ferrari dealer for it. I imagine the car has cracked and checked by this time. It's been 40+ years since it was laid on.
csxsfm
Was the builder "Dennis" as in Dennis Zainfeld?
Quote from: csxsfm on February 16, 2023, 04:46:58 PMWas the builder "Dennis" as in Dennis Zainfeld?
Yes - he built the Pantera for a guy in Utah. Chuck Beck is the one who made the engine compartment 9" wider to fit the Cammer https://newsandviewsusa.com/chuck-beck-living-legend/ He's still going strong at 85 - he was also a fabricator at SA on the GT40s. Dennis moved his shop 3 times while the Pantera was being built - that was a chore. Dennis' parents lived next door to a friend of mine. Across the street was Rick King a guy whose Red 55 Tbird with a blown BB Chevy was in Hot Rod a couple times (his mom bought it new and within a week of Rick buying it he had a 327 Chevy in it - his dad was not happy). Around the corner was another guy whose dad had crewed on a 67 Kar Kraft TA Mustang he owned a dyno tune place we always used after hours. The kid Steve Dragus built a 60 Falcon with leftover TA parts a full cage and a Hilborn injected HM small block. It was a pretty competitive neighborhood. Both of them have passed away now.
As Ken Young would say - only in Southern California.....
OldFordGuy
#23
There was a 427 on Los Angeles Craigslist the other day (gone now). Had an H scratch. Guy wanted $6500 for it. Does that H scratch mean it was a cammer block? Man, someone got a real deal if that's the case.
ETA: 1965 CXXX-H block, did not appear to have cammer heads on it. Chrome valve covers. Single 4 barrel.
azdriver
My C5AE-H block has an H scratch on the back...
Pat
OldFordGuy
Quote from: azdriver on February 16, 2023, 09:57:51 PM
Pat
And is it a cammer? (I'm trying to learn how to identify one).
azdriver
No it is not so apparently the H is not cammer specific..
Pat
OldFordGuy
Quote from: azdriver on February 17, 2023, 07:40:38 AM
Pat
So, from what I can gather there is no way to ID a block as a cammer without removing the heads. Does anybody want to correct me on that?
https://www.diyford.com/how-to-identify-a-ford-big-block/
This is the 427 SOHC Cammer Side Oiler block. What makes this block SOHC-specific is the oil drainback passage (arrow) for the hemispherical heads. You can run wedge heads on an SOHC block. However, you cannot run SOHC heads on a wedge block.
Correct rear of sohc block has raised hump where it is drilled out at top of block corner to route oil back in the pan and  bottom oil hole can be seen on rear corner of block by the steel crank. There were several versions and castings ID of the 427 side oiler block from early to late and cavity moulds sand castings of the raw blocks.  Another way to tell a sohc block id no cam bearings in middle and rear since only need the front cam bearings for the short stubby cam that turns the dual point distributor. Some cobras  reportedly came with sohc blocks of which will work on FE heads but u cant run sohc heads on any block but a sohc block.
