frame side motor mounts
Started by corbins, March 25, 2023, 02:26:00 PM
corbins
69 CJ going in. But not really. I have the rt side mount to frame where it belongs, x-member is in, wondering if small and big block frame mounts marked the same and if so, is there a noticeable difference between the two?
This bitch will NOT fit between the frame mounts ! One side will drop in the other just gets hung up and cannot drop into place. Sooo I'm wondering if I got a pair of small block mounts on the frame. New insulators and block plates are properly installed I'm pretty sure (2 bolts to the top).
I have never had this much trouble trying to get one of these muthers set in the car!
Thanks for any suggestions !
The engine mounts to frame are different from big block to small block.
corbins
Thanks Pete ! I think I just figured out that I have small block mounts ? Pic
