Door armrest removal
Started by Thanx2cs, April 06, 2023, 03:24:03 PM
Thanx2cs
I need to get my passenger side door panel removed to fix the door handle.  I need to remove the armrest.  Problem is I need to remove the decorative buttons.  Clearly they have never been removed and I'm trying to not butcher it up in the process.  Any tricks I should know about?
68blk500c
The caps with the woodgrain press onto the base.  Take a plastic credit card and use the edge to work into the small gap (at a corner) and gently pry the cap away to reveal the screw below.
