67 GT350 Original Radiator and Fan Shroud
Started by mtdubvee, April 07, 2023, 10:16:06 PM
mtdubvee
I'm looking for a nice original WMO radiator and fan shroud for a 67 GT350. 4 speed non AC car.
Matt
304-228-4732
SFM 5S123
SFM 5S269
1967 GT350 #41 Raven Black 4 Speed
Quote from: mtdubvee on April 07, 2023, 10:16:06 PM
Matt
304-228-4732
Any preferred date range or does that matter? FYI the fan shroud and 4 speed radiator were the same regardless of if A/C or not. 67 GT350 were specified to have the heavy duty cooling radiator.
mtdubvee
Early double digit car built in October 66 so correct for that would be perfect. You have something Bob?
SFM 5S123
SFM 5S269
You may not be aware but the C7AE-B marked fan shroud came in two varieties . You may want to distinguish which one in case it matters. The hardest to find and consequently most expensive to those that are informed were marked with the FOMOCO in block letter inside a rectangle. Those came on nearly cars. The later production style maybe March 67 forward had the FOMOCO in script letters inside a oval.
Quote from: mtdubvee on April 07, 2023, 10:25:01 PM
Sorry no WMO 4 speed radiator just a one for Dearborn or Metuchen heavy duty cooling 4 speed car . I do have a one of each variety fan shroud.
mtdubvee
I need the early shroud that has Fomoco inside a rectangle. C7ZE. Do you have that version?
SFM 5S123
SFM 5S269
visual reference,
Quote from: mtdubvee on April 07, 2023, 10:50:36 PM
Yes  i presently have one of each version.
hertz1966
There is an original fan shroud on craigslist
This is not mine, just passing along information. I tried buying the fan shroud without the radiator, however, the gentlemen would not separate.
https://chicago.craigslist.org/wcl/pts/d/woodridge-mustang-speed-radiators/7606081518.html
1967 1968 Mustang 4 Speed Radiators
Original FoMoCo Ford 67' & 68' Mustang 4- Speed Radiators....
1 - 1967 Mustang GT390 Big Block 4-Speed Radiator --- C7ZE $700.00
1 - 1968 Mustang/Shelby GT350 Small Block 4- Speed Radiator with C7ZE shroud -- C8ZE-G1 $500.00
Both Radiator are un-tested and have been sitting for many years, so might need to be re-cored.....
OBO
Text or Email, 630-Two Four Seven-One Five Two One
nightmist67
Check with All Classic Motors for the radiator.  Their website claims that they have various date-coded 4-speed extra cooling WMO radiators available.
64kcode
Matt
304-228-4732
Hi Matt, i called you last week in regards to a 64.5 K code coupe and left a messiage , i will try again this week ,thanks. chuck.
mtdubvee
SFM 5S123
SFM 5S269
