Correct Paint for the 67/68 9" Rear End Housing
Started by Kent, April 13, 2023, 05:44:35 AM
Kent
hello, what is the correct paint for the 9" rear end housing? I know its a satin black but what kind of paint was it? epoxy, alkyd, etc. I just try to figure it the right way. I think they were no primered before the paint. Maybe someone can help me.
I dont think "satin" black was used. To me that implies it has some sparkle. Ford used a  semi gloss black enamel on original housings. No primer was used.
Quote from: Coralsnake on April 13, 2023, 07:07:09 AM
+1 .There was a somewhat of a range in between too shiny or too dull. The paint could vary in sheen depending on batch,humidity etc. when it was shot at the mfg.
Kent
Yes translation, satin black in Germany is what you call semi gloss. So someone has an idea about what they used as paint? Epoxy, or is there an advice which brand is ok to use?
Kent
Ok so its the same style of paint like they used for the engines? So which brand is ok to use for the rear ends?
Sorry, I guess I dont see why the brand is important?
Quote from: Kent on April 15, 2023, 01:13:14 AM
I've used rattle  cans and I have used single stage PPG black  with a hardener and flattening agent and both held up well over time. Prep is always the key.
Bossbill
Are you using a spray can or a custom mix in a spray gun?
What brands are are available there?
In spray cans I've noticed that SEM semi gloss is flatter than the Rustoleum semi gloss. And even within the Rustoleum brand there are differences between Fusion and other mixes.
I shot mine in SEM semi gloss from their canned product line. It matches the gloss of their can.
Either way I thought it too flat and reshot it.
Personally I like the "look" of Rustoleum in a can for many semi gloss applications.
Note too that the high temp semi gloss  version of some brands is shinier than their regular mix.
70 B302   6/6/70  0T02G160xxx
Quote from: Bossbill on April 15, 2023, 10:09:40 AM
Lets see depending on how I want contrasts in parts using rattle cans  I have the Krylon "industrial" 1613 which dries REAL FAST which I like. I got 2 cases from a friend who ordered it and went to another direction on his engine bay. I have used Krylon "rust tough" semi flat, Rustoleum painter's touch in semi gloss and also satin. Mostly semi gloss. temp humidity etc and I just either like the look or use something else for the conditions.
Kent
I can paint with rattle cans and also with a spray gun, I also have access to powder coating. So that's not a problem. In Germany we can buy VHT Paint and I think they have an enamel paint in satin black. Did someone tried these? How close is it to original? And is powdercoating maybe an option?
Quote from: Kent on April 16, 2023, 01:28:11 AM
................... How close is it to original? And is powdercoating maybe an option?
If your going for the original look then powder coating IMHO is not an option.
here is the original paint on a rear axle housing.
I typically have the rear end housing and backing plates bead blasted then powder coated semi gloss black.
