Help - removing BW T10M1 tail shaft
Started by 6s1640, April 19, 2023, 06:46:55 PM
Hi all,
I need some guidance on removing the tail housing on a Borg Warner T 10 M1 transmission. It is leaking between the tail housing in the main case. I know there's a pin needs to be knocked out in the tail housing plus four bolts.  Do I pull the shaft out that the pin is holding in?  Also, any other suggestions?
CSX4781
Hey Cory,
  Just sent you a PM, let me know how it works out.
Hi Dave, I just read your PM. Thank you. Also, I saw a YouTube video that talked about the reverse fork having to be disengaged. Will that be easy to reassemble to reengage?
Thank you
Tomdeg
It's tricky. I would suggest practicing several times without the gasket and sealer to get the feel. I've wasted many gaskets :(
Hi Tom and Dave,
Thank you for the input.  It really helps to get some guidance before attempting something new.  Together, we are smarter.  Thank you
Take care
