A bit of Shelby shame.
Started by deathsled, July 01, 2018, 06:22:21 PM
deathsled
I hesitate to post this pic but I will do so along with the following inquiry.  This can't be right can it?  That aluminum disk that goes where the eye bolt screws in for the lap belts. It should be under the transmission tunnel and not over the carpet right?  The shop that did some of the assembly seemed to think it was correct (obviously or they would not have done it that way) but reasoning it out in my mind shouldn't that disk be where the bolt goes underneath to prevent the bolt from being ripped through the floor if under the intense stress of a severe stop?  Same question on the side where eye bolts go into frame.  SHould there be a disk there as well or not at all?
Eagle eyes will note that the wrong belts are in the car, but Acman redid my belts and they turned out amazing.  So much so, it's making me hesitant to put them in the car.  Along with an outstanding job of refinishing the Cobra intake.  I couldn't be happier!
And yes, that is a red fire bottle in the back seat on the driver's side.   I should have two just in case.
Engine revving to disturb
Quote from: deathsled on July 01, 2018, 06:22:21 PM
Back in the day no disc was used. After market disc and eyebolt.
deathsled
Thank you Bob.  I knew you would charge to the rescue.  I will ditch the disk.  Thank you again!
Doesn't go under either. There is a plate with nut spotwelded underneath so no room for a washer.
Greg
Can someone post a picture of how it is suppose to look?
Shelby's and Fords from Day 1
acman63
take the plate out and thats what it should look like on the inside
SAAC Concours Chairman
Greg
Quote from: acman63 on July 02, 2018, 03:45:05 PM
Do you know what the correct eye bolt looks like?
GT350Lad
Nicely done, pics aren't working for me but they are marked G3 on the bottom of each side of the eye  of bolt
Cheers
6S373
6S1276
Quote from: GT350Lad on July 02, 2018, 04:38:33 PM
Cheers
Those are the ones you want.
Greg
Thank you for the pictures.
Quote from: J_Speegle on July 02, 2018, 04:30:40 PM
Quote from: Greg on July 02, 2018, 10:35:43 AM
I think the original eye bolts in 843 had a flat about 3/8" wide on top. It did have one chrome end belt and one cad plated - for some reason.
GT350Lad
That's true I think mate, from memory on my original belts the door side floor bolt is slightly flat on top compared to the tunnel one.
Cheers
6S373
6S1276
deathsled
Found my G3s in a box of leftovers.  Nice.
