Can't Install Brake Drum After Shoe Replacement
Started by SHELB66, May 02, 2023, 09:02:04 PM
SHELB66
Quote from: trotrof1 on May 02, 2023, 09:58:28 PM
In addition, make sure the emergency brake cable is completely releasing. Lightly tap on the lever/cable hardware behind the secondary shoe. A small movement will allow a increased air gap.
Turned out this was the problem.  Apparently the emergency brake cable, even though released inside the car, is not fully releasing in the rear.  That was probably my initial problem.  For now I just disconnected the cable from the lever inside the drum.  Everything fits fine.  Since this car was exposed to the elements for many years it will be receiving lots of new replacement brake parts for safety's sake.  Thanks to everyone who responded to my inquiry.  Much appreciated!
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
02 Explorer Sport Trac
I appreciate the closure post because I had been wondering and I am sure others too what the problem was.
SHELB66
I just got back to working on the car today.  I'd work on it everyday if I could!  There's just too much else going on right now that carries a higher priority (at least that's what my wife says).
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
Lincoln tech
I told you we'll get this thing fixed  ;)   Nice work Graig.
greekz
Good job!  It is hard to fit the fun work in between the honey-do's.
SFM 6S1134  '67 GT-350 #2339
trotrof1
Glad to see you found the problem. Collectively we usually can help narrow down electrical /mechanical issues.
SHELB66
My Hertz now has all new brake components from front to rear excluding rear drums and backing plates (thank goodness!).  All is good and I'm back on the road again.  I almost forgot how fun it is to drive this car!  Time to move on to the next item on the "66 Hertz" list.  Thanks again for everyone's assistance.  I know that more questions will be coming!
Craig R.
66 Hertz 6S1564
06 Hertz #446
64 Ranchero V8 4spd
