Oem lower side scoops 68
Started by 68cobra427, May 13, 2023, 12:39:07 PM
68cobra427
After getting one of the early drivers side and with help from here seeing there was 2 versions I found another drivers scoop and it ended up being later style. for sure shape difference and hole location. Interesting wonder why the change would be needed.
azdriver
My car, 3/14/68 has the later style scoops. I wonder why the Shelby lower scoops were left open and the GT/CS scoops are not?
Pat
68cobra427
Good question. Here is my Nos GT/CS scoop.
68cobra427
Also wondering if the GT/CS is identical to the High Country Special. Orig is there a difference there as well.
How do you know its a change ?
Maybe its just two different molds?
68cobra427
Could be a mold change.  I talked with someone that has a oem early scoop and his is missing the part that attaches the front. Possible the early did not hold up as good . Therefore the difference in the mold and using the outer location to mount the scoop in thicker fiberglass area.
