Which rearend housing for an earlier 1966 car?
Started by cboss70, June 07, 2023, 08:16:45 AM
cboss70
Do all 66 Shelby's have the 9" with the rear bump out or did some of the early non-carry over cars have the round back? I have a friend with a car with a December build date (maybe around car 300+- cant recall) and I assume it's one with the bump out (not round back housing) but figured you never know since his car also originally had overrides.  Was there a transition date for the two housing styles?
GT350Lad
As far as I know only carryovers had the 65 style. If your vin has 6R09K it's a humped housing.
6S373
6S1276
cboss70
Thanks, If the 5/6 VIN is the deciding factor I'll just tell him to take a look and use that as a guide.  Thanks for your help.
Was there a specific date change? The Mustang K collectors may have an actual production date for when changes occured.
https://hipo-mustang.com/
Quote from: 98SVT - was 06GT on June 07, 2023, 02:09:17 PM
Was there a specific date change? .............The Mustang K collectors may have an actual production date for when changes occured.
At least at San Jose likely not it appears. More likely a range when it too place would be the closest we could/can determine. Two problems - #1 we don't know specifically when each car was built (as Mustangs) and #2 when the change over took place they likely used up what was in the supply pipeline and in the small inventory at the car and at Sterling that supplied them and they likely were not concerned about which got used in any particular order since the change did not affect any of the other parts on the car unlike other running changes that took place (example change over from generator to alternator where there were a bunch of related parts that needed to be changed all at the same time.
