Can anyone ID the serial number of this car
Started by acman63, January 21, 2018, 08:56:43 PM
acman63
I can't recall where this pic came from but looks very period,  I can see the stamped number but can't read it.  anyone have an idea?
SAAC Concours Chairman
BGlover67
Brian R. Glover
EdwardGT350
late car since it has the valve cover hold down brackets?
btw what is the plate thingy above the alternator.
also is there body color overspray on the hood hinges and export brace?
1966 GT350 6s1761
Shelby_r_b
Nothing beats a classic!
I would have guessed it was a post mid April car with a possible VIN above 2000 based on the few clues in the picture.
It has been suggested that the car may be 6S2186 or 6S2169
Quote from: EdwardGT350 on January 21, 2018, 09:42:19 PM
I am not sure what plate thingy you are seeing.It all looks typical . Maybe you are seeing the superimposed starter solenoid and wires.The over spray on the hinges would indicate some previous non factory body work. there are other maintenance things that have been changed like filter and positive battery cable. The cable is a little strange to be changed given the assemblyline battery which typically would only last 2 or 3 years. The positive battery cables are typically good for many years of normal use.
EdwardGT350
what is the silver aluminum plate just below the coil?
1966 GT350 6s1761
acman63
love the remnants of the engine ID  paper tag on the coil and the lighter blue Fomoco adjustable shocks
6s1802
It has the valve cover hold down tabs, I have 1802 which has the tabs, Brant Halderman knows the serial number spread when they were used. That should narrow it down.
Quote from: acman63 on January 21, 2018, 11:08:49 PM
The light Ford blue engine paint is almost a exact match to 66 shocks that are the blue. Much later 66 shock versions were black.
GT350Lad
#10
Quote from: BGlover67 on January 21, 2018, 09:37:37 PM
Where is Abby from NCIS when we need her?
Agree, I was thinking maybe the new forum has the tech to blow it up and enhance it  ;)
6S373
6S1276
mgreene
'66 GT-350H
'69 428SCJ Mach 1
'72 Pantera
Have you tried enlarging the right side stamping? It almost looks like Al Jardine of the Beach Boys?
SFM66H
I have this info in my files about the car in this photo:
It's 6S2169, sold on 6/29/66
This photo was taken in Dec 1966, and may show the first owner, Raleigh Dunson of Des Moines, IA
