1964-1970 Mustang Horns Differences?
Started by Kent, July 10, 2023, 02:03:38 AM
Kent
is there maybe a good thread or something what the differences are on the Mustang Horns? I know 69/70 had a different bracket. But 64-68 is not really clear for me. Any help is appreciated.
Kent
Can someone help me? I just want to divide the differences in the horns over the years. I think the bracket and also how its mounted on the horn are the major differences I can see.
Yes there are many bracket configurations. Some years the horns are specific to AC cars
Kent
yes that are the ones with the 2 hooks instead of 1 hook on the non ac. But how the brackets are mounted is also different I will post some pictures what I mean.
THE HORN WORKS
Restoration Specialist of Collector Car Horns
967 Hackett St. Beloit, WI. 53511
608-361-0095
Mon- Fri  9 - 4    Sat  9 - 1   CST
The Horn Works - Car horns repaired rebuilt and restored
https://thehornworks.com/
Marcus Aurelius
Our pronouns are We Won
"Usque Ad finem"
Kent
That really helped thanks to all, I didn't knew that Marcus made a pdf about the horns also. But its just for 69/70 is there some more information about the 67/68?
Kent
I did some pictures of some 67/68 Horns now, and there are some I´m not sure wat they are for? Maybe we can work it out here.
Kent
These 2 I´m not sure what they are for?
Kent
Can someone maybe check the pictures? Some are obviously 67/68 but on some horns the brackets are in different positions. The one on the right side with the AC Mustang 67/68 bracket is something I know. The normal ones also. But there are some brackets I´m not sure with. Thank you.
Corey Bowcutt
Kent,
Unfortunately, I can tell you nothing about horn differences over the years.  But I can tell you that the 64.5 horns are very different from any other year.  They are mounted in the engine compartment on top of the 45 degree frame rails adjacent to the fan.
Corey
Kent
this is only about 69-70 horns but I talk about the 67/68 maybe Marcus should do version 2.0 I can help him out with pictures.
Kent
#13
Does someone here can see the differences between all the horns on my pictures and tell me what they are for, I was able to identify some but some are a mystery to me.
I just marked the ones on the pictures and the ones in the first picture are also ones that I dont know what they are for.
The ones you have circled are not correct for 1967 - 68 Mustang or Cougar. I don't know what the specific application is but some other Ford or Lincoln Mercury product from the era.
