65 GT350 dist to coil wire
Started by mygt350, July 11, 2023, 10:26:14 PM
mygt350
Am interested to know what length the black wire from dual point dist to coil was. Also interested to know how dist case was positioned in the block. Any pics of top of coil and dist position is appreciated.
Don't have one near me to measure. Was the same length as other 289s
Pictures I can help with. From the period
Quote from: mygt350 on July 11, 2023, 10:26:14 PM
The distributor case of the duel point when indexed into the block properly and timed was very close to having the front hold down clip facing straight forward.
rockhouse66
Interesting to see the black booted wire; does anyone reproduce this style?  Also, the cap clips look like they are zinc plated - is this the norm?
Quote from: rockhouse66 on July 12, 2023, 07:49:41 AM
If you mean the bell shaped coil wire boot at the coil then yes that is typical and what Marti sets come with unless you get a mis made one. I think the clip in the picture is more on the bare metal side compared to the most typical zinc phosphate. If it were zinc it would show up much brighter in the black and white photo IMO. No I don't think it is from a camera flash Ed. :o
rockhouse66
Bob - no, I am asking about the 90 degree black boot on the threaded coil post on the end of the lead wire to the distributor.
mygt350
I measured three I have and find they are 12", 15" and 17" from end of lug to where wire would protrude from the case. IFrom what I am told, the points plate on a 289 dual point is identical to a 427. Were 427 wires same lenget as their smaller brothers?
mygt350
Quote from: mygt350 on July 12, 2023, 01:37:38 PM
12" seems most typical.  The point plates are the same between a SB and a BB duel point. The BB coil wire was typically the same length as the SB coil wire.
Quote from: rockhouse66 on July 12, 2023, 12:41:42 PM
For a long time Marti was putting a 90 degree boot on the coil side as well. Thankfully he changed that. The style in the picture of the 90 degree boot is the typical one I have seen on SJ GT350's. The Marti 90 degree coil wire boots are a different style (shape) and are a "tell" that they are not right for a GT350. They must be correct for some applications given he makes them up from engineer drawings just not right for 65-67 SJ smallblock's from what I have seen. 65-67 SJ smallblock's came from the same Cleveland engine plant and I assume the wire sets were installed there.
mygt350
Thanks Bob for sharing your knowledge.
rockhouse66
#11
I'm not asking about the ignition wire  ::)   The lead wire from coil to distributor.  Not the wire from distributor cap to coil.
Quote from: rockhouse66 on July 12, 2023, 06:55:35 PM
Yes, the wire from the dist to the threaded terminal on the coil with the black eyelet for a hipo dist is reproduced. check the regular sources like NPD.
