Can't include attachments - Your attachment has failed security checks.....
Started by Rodster-500, October 02, 2023, 03:54:05 PM
Rodster-500
Your attachment has failed security checks and cannot be uploaded. Please consult the forum administrator.
What are the security checks?  This is a new one to me.
computerworks
Quote from: Rodster-500 on October 02, 2023, 03:54:05 PM
Try again...and if it persists, PM or email the details
TA Coupe
I've had this happen several times. I think that the system can detect copyright items and block them. I know this can happen on some systems. When this happens I can usually send the pics to myself and download them and then send the downloaded pics to the forum and they will work. Make sure what you are sending is not to large as a lot of forums have a limit on size.
       Roy
If it starts it's streetable.
Overkill is just enough.
computerworks
In Rod's case... There is some metadata in the image that is causing it to be blocked....probably copyright as mentioned above/
I'll investigate...but I "cleaned" it and sent him a version should work...
Rodster-500
Thanks for the help. If you determine what the metadata is let me know. It was just a jpg image taken and edited with my cellphone.
HOW TO IDENTIFY A FORUM TROLL
Rodster-500
I had to remove all of the metadata to get it to work. None of it is copyright related just camera information.  Very odd.
Quote from: gt350shelb on November 19, 2023, 10:16:34 AM
how do you check fr meta data and or remove it ?
Right click the picture on your computer and look at properties.
computerworks
When that happens, just open the image in a Paint program and save it ,,,that will remove the Metadata
TA Coupe
What I do is send it to myself then download it and it's ready to go
      Roy
