Leaking Holley Carb
Started by Steve Meltzer, October 09, 2023, 09:16:12 AM
Quote from: Steve Meltzer on October 10, 2023, 10:34:20 AM
Thanx again, guys! Peter L., not being as familiar with these carbs as I hope to be, help me to decode mine, b/c i thought it was correct.
All numbers, etc are cast/raised, not stamped/engraved.
C30F-9510-AA (is this Ford part number?)
List-4174 (double pumper, 4150 and correct from what I've read. No?)
854 (May 4, '68)
thanx again. taking notes to learn.
Newbie, steve meltzer
You mis read the engineering number which is C8OF . Yes it is for C =1960's and the 8 is for the year in the 60's . It is not a double pumper.
Lincoln tech
854 (May 4, '68)
C3OF would mean 1963 ????
Quote from: Peter L. on October 10, 2023, 10:11:24 AM...... since the OP stated that it was a double pumper. Not the correct carb to start with anyway.
Light bulb moment - why aren't we looking at the accelerator pump diaphragm?
That list number corresponds to the 428 CJ / 4 speed carburetor
Lincoln tech
Quote from: 98SVT - was 06GT on October 10, 2023, 10:58:03 AM
Now those I have seen leaking , should be easy to diag since it looks like he has the carb removed . I still don't get how the inspector saw the power valve leaking ??? I think he meant accelerator pump , something is fishy here .
854 (May 4, '68)
The picture clearly shows the numbers to be C8OF 9510-AA.
Peter L.
 That is indeed the correct carb for a Cobra Jet. Perhaps you were referring to the fuel transfer line on the right side of the carb. Common mistake. A 'double pumper' would have an accelerator pump on the rear bowl as well.
As I posted earlier, that is a $$$ carb, and definately worth repairing correctly.
  Good luck!
KR 4052
Steve Meltzer
Gawd I hate the taste of crow before noon! Clearly i saw the 2° metering block and the fuel transfer line and (never having had a Holley other than 4160s) I assumed there was a second A-pump. The 2° metering block makes it a 4150, right? Or do I have that wrong as well?
Maybe my X-wife was right: it's a wonder I made it this far in life w/o her! thanx again. steve
Steve Meltzer
Oh yeah...and two more things 1) I did think it was leaking from the A-pump diaphragm, and replaced it. Confident now, it's not leaking from there. B) How did the inspector know/think the leak was from the PV? Beats the feces out of me, as you can't see the PV in the bowels of the metering block. When queried about just that, he said "b/c that's a common site for Holley leaks". s
Quote from: Steve Meltzer on October 10, 2023, 03:14:01 PM.....How did the inspector know/think the leak was from the PV? ....he said "b/c that's a common site for Holley leaks". s
One sneeze (backfire) can kill the power valve. About 10 years ago Holley came up with a fix and has used it since them. You can modify the older carbs with their kit. https://www.holley.com/products/tools/carburetor_tools/parts/25-100QFT
I've been working on Holley carbs for 50 years and have yet to see a blown power valve. It seems to be something that happens a lot on the internet.
I have occasionally seen power valves that have rotted out from age. In those cases I was rebuilding the carburetor anyways and the power valve was headed for the trash can.
Fuel leaks externally could be from a half dozen places. The transfer tube and it's bowl adapters, metering block or bowl gaskets, and the eight gaskets on the bowl screws. A carburetor that expensive deserves special care from someone who knows what they are doing.
Lincoln tech
Quote from: Royce Peterson on October 10, 2023, 03:55:04 PM
You took the words right out of my mouth  ;D They also sell a power valve block off plug.
trotrof1
+1 on the bowl screw gaskets. You might need to wipe dry the bowl assembly well and scrutinize closely to catch it.
It happens or they wouldn't have made the change. I popped one way back when. I had the timing way off during the start of a fresh 440 for my Road Runner almost lost my eyebrows on that one. But maybe a Ford won't sneeze hard enough.......
Quote from: 98SVT - was 06GT on October 10, 2023, 05:02:44 PM
Not only does it happen but it happens quite often, not on my internet, on my Holleys. Consider yourself fortunate. ;)
