68 Shelby rear panel screws
Started by shelbydoug, October 11, 2023, 08:48:49 AM
Quote from: shelbymann1970 on October 17, 2023, 06:54:21 AM
Quote from: Bob Gaines on October 16, 2023, 10:38:11 PM
I thought " https://www.deadnutson.com/ " sold the gray panels but none show on his website anymore. You might call to be sure because it would certainly be the best alternative IMO. If he doesn't you will have to modify the black ones to make them look more authentic. . The repro material is not near the same as the original which was water resistant and had a smooth non porous surface unlike the rougher black paper that has a somewhat furry to the touch surface. You need to seal it with some coats of grey filler primer and do sanding between coats so that if is smooth when you lay down the final finish of grey so that your new pair match's the one panel that still exists in your trunk. After the final coat I use a semi gloss clear to complete the process to mimic the finish on the originals. I hope this helps.
I got a pair from DNO but they have a "reverse" bend I have not gotten out yet. I haven't tried. Thanks for the tip as I have 1 original panel from my car and I'll try and duplicate the finish on it.
Thanks for bringing up the bend. The boards should be pre bent and not bent to fit when installing in the car. There were typically no creases in the factory panels . The crease will most likely happen if you try and install without pre bending. I find something with a large rounded surface and carefully persuade the cardboard back and forth to bend without putting a crease in the board . Once the board has that bend memory it will be easier to install with out putting a crease in the card board.
Steve Meltzer
Bob, Would heating the piece with a heat gun help with the bend as well? thanx steve
Quote from: Bob Gaines on October 17, 2023, 10:26:44 AM
Mine came from Jack with the bend backwards. I wish I would have bought the vert trunk divider as a spare when he had them. I'm told probably gone forever.
Heating them probably wont work
They dont need to bend much, using a round concrete form, to slide the cardboard into and gently applying even pressure, leave overnight and they are formed
Quote from: Coralsnake on October 17, 2023, 12:13:25 PM
Thank you. I got one of my originals for the shape. So DNO pieces are for 69 and 70 so what is different about 68s? Anything?
The shape is different between the 1968 and 1969 models. 1969s generally have screw holes as well
+1 .
Steve Meltzer
Two basic questions here:
1) etching or non-etching primer?
B) Is the rearmost surface, the one you don't see, black or blue-gray?
thanx steve
Black on inside blue/gray on side you see
Primer gray is close, but its actually closer to a Volkswagen color from the 1960s. Sorry I dont have a code or color name.
Its going to soak into the cardboard, so you will need several coats
Steve Meltzer
So, primer gray when all done, or blue gray as your website suggests?  Sorry for the redundancy. s
Quote from: Steve Meltzer on October 18, 2023, 10:39:51 AM
I think the color of the ones Jack sells is pretty close if not spot on(have yet to do a side by side comparison). I have an original one put away from my car and I was thinking of getting the paint color matched at painter's supply next summer. I've done that with PS pumps and 69-70 Shelby grill/bucket color.
I think thats answered?
"Primer gray is close, but its actually closer to a Volkswagen color from the 1960s."
I'm starting a new topic on the trunk dividers.
