Leaking Holley Carb, now need KR starter
Started by Steve Meltzer, October 12, 2023, 08:52:16 PM
Steve Meltzer
Gonna need a new ?rebuilt starter...dunno nothing about if the one i have is original, etc. Thanx, steve meltzer, obvious newbie
rhjanes
Check this for component ID first.
https://www.428cobrajet.org/id-starter
You used to be able to purchase a kit for rebuilding starters.  Not sure you still can.  they are fairly easy to rebuild.
Steve Meltzer
Thanx for the info! In the weeds now! When you turn the key, it is silent, DEAD! Am I right in thinking it could be the solenoid, not the starter, or, isn't there a starter relay? thanx so much. s
"When you are up to your ass in alligators, it's hard to remember that you originally came to drain the swamp"
jk66gt350
Power goes through the starter solenoid then to the starter.  If the starter is done, you should still hear a click at the solenoid when you turn the key.  Bad solenoid?  Bad key switch?
Steve Meltzer
lt's bedtime for this old fart, but hope to check the voltage at the relay and solenoid tomorrow. Should help to narrow this a bit, then, back to the errant Holley. s
Lincoln tech
Steve , Steve , Steve lets start here , Is the battery fully charged ? Simple self powered test light may help you a lot to diag this problem , starter solenoid can be jumped to test it at the same time it will tell you whether the starter is working , just be very careful when you attempt this vehicle must out of gear and ignition switch in the off position , is your car auto or 4spd ? There may be a lot other things that will cause a no crank condition start with the basics .
And then you have got the tilt mechanism which could be hindering your ability to start.
Lincoln tech
Good video on test lights ( Just make sure to get one with the old fashioned light bulb which will load test your circuit  ) A must have in everyone's tool box .            https://www.youtube.com/watch?v=bmCGgDtCAYA&t=367s
Lincoln tech
Quote from: Coralsnake on October 13, 2023, 09:24:28 AM
Yes , I just didn't want to go there yet  ;)
Make sure the door is closed and the steering wheel is straight in-the driving position before starting the car
Lincoln tech
Quote from: Coralsnake on October 13, 2023, 09:58:08 AM
100%
Lincoln tech
I have seen guys pull the dash out of the car to try to find an electrical problem , but the only thing that was wrong was a blown fuse , start with the basics .
Steve Meltzer
ARRRGGHHHGH! Rookie mistake (again)...the door was open and the steering wheel cattawampus. Fired right up when those errors were corrected. Now, back to swamp (fuel /Holley leak). thanx again, guys. s
Lincoln tech
Np , at least you own up to your mistakes some guys just lie after they screw up (I could never understand why ?) So you saved a couple of bucks , If we ever meet your'e buying lunch  :)
Steve Meltzer
@Lincoln  Tech you're on as long aa you don't eat kale or Brussels sprouts. s
