1967 GT350 Radiator Tone
Started by Joebantelman, November 17, 2023, 03:56:15 AM
Joebantelman
I ve noticed the tone/hue of black varies on 67 GT 350 radiators. I've seen Satin, Semi-Gloss & Gloss. When
Judged concours is there a correct tone?
Originally they were painted with a gloss black lacquer paint so that it would dry quickly once applied that quickly became a flatter finish from multiple heat cycles and use.
Joebantelman
Quote from: J_Speegle on November 17, 2023, 04:21:09 AM
When did they start using the special Black Paint just for Radiators?
Quote from: tesgt350 on November 17, 2023, 08:31:08 AM
Not sure what was special paint it was just lacquer.  Pretty much same stuff local radiator rebuilders were using though the years also.  The Modine and other  suppliers had used black lacquer at least back to the 40's
Not sure what was special paint it was just lacquer.  Pretty much same stuff local radiator rebuilders were using though the years also.  The Modine and other  suppliers had used black lacquer at least back to the 40's. This wasn't a Ford "thing"
i think that you are referring to the modern radiator paint that Eastwood and others sell that is supposed to have special properties allowing heat better heat transfer through the coating. Ford's suppliers used cheap lacquer as Jeff mentioned.
